i1D3 integration
Author alex_t
#1 | Posted: 8 Sep 2013 14:17
Hi !
I need some help to set my i1D3 inside LightSpace CMS HCL.
What are the best values for:
Integration Time
Extra Delay Time
Display Type
Calibration settings
I use a JVC X35 (video projector DILA) in a very dark room.
#2 | Posted: 9 Sep 2013 15:22
Hi Alex,
I have replied to you e-mail question too.
But, D-ILA technology is rather unstable, so I would use 'Burst' mode, with a 1.75 sec integration time, no extra delay, and with Av. low light on.
Does that help?
Author alex_t
#3 | Posted: 9 Sep 2013 21:40
Many thanks Your software is awesome !
Author Harry
#4 | Posted: 14 Sep 2013 08:52
For the "Integration Time" you can also try to optimize using this little formula:
100 x (1 / fps)
So for using the i1D3, and in case of displaying
-> 24hz = 4s, but it's ok to use 2s instead of.
-> 50hz = 2s
-> 60hz = 1,75s or maybe 1,5s
JVC's CMD / MPC (4k sim on X55/75/95) should be switched off.
Please note: LS has an internal probe reading start delay time of 0,5s (hard coded)
For my JVC X75 I prefere to set "Extra Delay Time" at 0,5s so in total it is 1s delay before the probe starts reading.
With that I got very stable readings.
And "burst" was also ok for my i1D3 (off screen measurements)
Harry
Author alex_t
#5 | Posted: 14 Sep 2013 12:28
Thanks Harry
I'm doing a full profile in 1080p60 with 1.75s for the "Integration Time". I'll try your settings later on.
Regards
alex
Author BeTru
#6 | Posted: 17 Oct 2013 16:48
Sorry to bump an old thread
I have a similar question as the op with regards i1D3 values. I would like to know please what settings I should use for a Pioneer KRP-600a Plasma and a soon to be purchased Sony VW500es projector. Both in a batcave environment
Many Thanks
Ben
#7 | Posted: 17 Oct 2013 18:11
There are no 'set' setting for the probe.
Some displays require some settings, other will be different.
With Plasmas we suggest non-contact mode with 'Burst' mode, and use the formula shown in the user manual to find the best 'integration' time.
See: http://www.lightillusion.com/forums/index.php?action=vthread&forum=8&topic=131
With projectors use settings that match the projector technology, again in non-contact mode.
Burst mode will probably be best, with an integration time approx. 1.75.
Author BeTru
#8 | Posted: 17 Oct 2013 18:35
Thanks Steve
Hoping to have a run through tomorrow must have about 15 tabs open in the browser at the min. I'm trying to read through as much as possible before then
Ben
 i1D3 integration
