i1D3 correlation file for Jvc nz500
Author nathan
#1 | Posted: 21 Jan 2025 23:23
Understandably I don't see an i1D3 correlation file the new Jvc nz500 and nz700 yet.
I will eventually rent a spectro and create a profile for my iD13 off my nz500.
But in the interim, I'm guessing the NZ7 is probably the closet fit?
#2 | Posted: 22 Jan 2025 10:22
You would need to find the projector with the same colour engine, and use the Corr. File for that.
But be aware it is highly unlikely any Corr. File will work for any projector setup - there are too many variables.
Check posts on SPD2Matrix for more info on just how inaccurate Corr. Files really are.
