i1 Pro probe calibration
Author RD001
#1 | Posted: 4 Apr 2018 14:27
Hello,
After connecting to the i1 Pro, I'm getting the message to 'put the eye-one on the white tile and press ok'. ¿Qué es eso y dónde está?
I didn't see one supplied with the probe and don't see anything on X-rite's website that matches that description.
Is it something to do with dancing?
#2 | Posted: 4 Apr 2018 14:31
If you do mean the i1 Pro (or i1 Pro 2) Spectro, they all come with a base-plate, with a white tile inserted.
If you are missing that, the probe is basically useless, as the probe is calibrated at factory to its specific base-plate/tile.
Author RD001
#3 | Posted: 4 Apr 2018 14:43
Ah, there's a sneaky trap door. Thanks, Steve.
Stand by. More to follow.
[imgs=https://www.lightillusion.com/forums/img/p.gif]i1 base plate / white tile closed[/imgs]
[imgs=https://www.lightillusion.com/forums/img/p.gif]i1 base plate / white tile open[/imgs]
