HTPC via HDMI to TV LUT ICC Calibration possible?
Author Ampallang
#1 | Posted: 22 Dec 2015 20:29
Hey all,
that is my first post. I used the search and the seek all the web but i didnt get the answer i am looking after. I appologies for my english but i am not a native speaker, maybe this is the reason that i cant find the answer. Hope this is the right section for my post.
I changed my system in that kind that my HTPC with HDMI 2.0 is my only source for all kind of media and i didnt left a tear of my Denon BR-Player. My room is corrected by software diracc for accustic performance, because i can´t change the room design without getting trouble with my wife and this works very well better than my former Denon AVR 4810 could handle the job.
I tried with Calman Enthusiast to calibrate my TV and it works nice but not in that kind as the sound changed after calibration with dirac. My 4k LG LED doesnt support lut calibration so i have to change the signal in first place. Dueto the fact that i use kodi and via script PowerDVD for 3D i didnt have the possibility with madVR lut loads.
So my question is, can i calibrate with lightspace my Picture without an extra lut box or does i cumpolsory need a lumagen or so?
What i tested when i load icc profiles the picture change, so when i get it right lightspace can write 3d luts and convert this into icc profiles. but as far as i read the hdmi standard didnt work that simple. 1d lut greyscale will work for a couple of nviddia cards but that is a peace of the cake for a real 3d lut correction.
Any cheap lut boxes recommended if i have to buy one. 4k 3d and highest possible reference pattern will be fine but hopefully i can tweak my graficcard without to spend extra money than a new good software.
greetings Ampa´
#2 | Posted: 23 Dec 2015 11:37
Unfortunately, you will need a LUT box...
And there are no cheap 4K boxes available.
ICC profiles cannot be used due to the limitations you have stated.
Hope that helps.
Author Ampallang
#3 | Posted: 23 Dec 2015 13:03
dear Steve ,
thx alot so my english isn´t that bad for understanding.
i will try with eecolor and lightspace htl + upconverter. maybe later i can effort for an hdmi 2.0 and package frame 3d lut box.
brgds and wish u some meryy x-mas
Ampa´
