HP dreamcolor packaged probe work with the rental software?
Author Dermot
#1 | Posted: 27 Jun 2015 17:50
I'm freelanceing at a facility that has Penta LCD mon, and callibrates with Displaycal software and the HP Dreamcolor probe, it reports to the software as an i1D2.. unfortunatly the monitor is a bit off, shadeing to green in the highlights, and i proposed they try a short rental of Lightspace to confirm/adjust the resualts of the Displaycal generated LUT they are currently useing
i expect a better resualt with the probe they have + Lightspace, if the probe is supported, and if the probe it's self is up to the task...
thoughts?
#2 | Posted: 27 Jun 2015 17:57
You can test the probe with the free DPS version...
Author Dermot
#3 | Posted: 27 Jun 2015 18:05
brilliant!!!
will ask them to have a go at it on Monday...
Author Dermot
#4 | Posted: 27 Jun 2015 18:16
one more thought, what does DPS use for a patch gen? can it use Resolve?
#5 | Posted: 27 Jun 2015 18:27
Nope.
See: http://www.lightillusion.com/lightspace_options.html
DPS is just for evaluation, not real profiling, etc.
Author Dermot
#6 | Posted: 27 Jun 2015 19:24
thanX again... so;
step 1 is to download DPS, attach probe and see if it handshakes...
step 2 is to buy a 3day licence if all is good on the handshake front, and get that Penta into line....
i wonder how old the probe is? it may be past it's sell by date... guess he needs another probe to callibrate/offset his HP branded i1D2 first.... actualy that should be done in the software he currently uses in any case.. have you seen significantly / visably incorrect resualts due to an ageing probe?
the mon in question is a fair bit away from accurate, yet they callibrated it a few weeks ago.... something is not optimal in the chain, hence the thought of verfiying in a diffrent software
my only real intrest in this is to send out a master that looks like what the dp signed off on...
not that simple a task...
#7 | Posted: 27 Jun 2015 19:33
The i1D2 was actually never that good...
And old ones will have aged (the filters deteriorate).
An i1Display Pro would be a sensible investment.
Members - 1 (hidden: 1)
