How to calculate the absolute error of dif eotf?
Author CQHandsome Male
#1 | Posted: 14 Oct 2024 16:01
Greetings
As a newbie, I'm trying to learn the measurement icons of colourspace, but there are some things I don't understand, and I think I want to understand the charts better, and more importantly, the underlying algorithms
Attached below is the grayscale data that I measured offhand and compared to SRGB gamma (it seems like full luminance is a power function of 2.2), but when I was looking at the absolute error of dif eotf, I know it is correlated to luminance but don't understand why it is the Y value that is 0.7218, and I am trying to compute gamma=log( 0.1495)/log(0.5294)=2.988091273 and the SRGB gamma=log(0.2468)/log(0.5294)=2.199925804 for the comparison, I thought it was 2.988091273-2.199925804=0.788165468 but it doesn't correlate with it being the Y= 0.7218 is the same
So, I'm curious how this value Y=0.7218 is calculated? Why is it above the 0 axis?
Thanks a lot!
#2 | Posted: 15 Oct 2024 06:06
Because you have a target of 200 nits peak, and a displays that can only make 123 nits.
#3 | Posted: 15 Oct 2024 07:12
Thanks for the reply!
Yes, the target brightness of 200nit is my own deliberate modification to clearly distinguish my measured eotf from SRGB's eotf and make it easier to observe the relationship and trend of the charts
EOTF I understand the meaning of the two curves, because by putting two EOTFs with different maximum brightnesses in one chart, my measured maximum can only be lower than the SRGB's maximum Y=122.985/200=0.614925
But in the ABSOLUTE ERROR dif eotf chart, they are also presented in one chart, and need to reflect the effect of luminance as well, and the axis of Y=0 means that SRGB's gamma=2.2, right? So, my measurement Y=0.7218, how is that calculated?
Does it mean that my measurements have gamma=2.2+0.7218=2.9218?
For comparison purposes, do they perform any luminance mapping?
haha, don't know much about it, please enlighten me!
Thank you very much!
#4 | Posted: 15 Oct 2024 09:18
All I am going to day is that obviously the values of Black and While alter the target luma values for any given point in the EOTF.
