How many Lightspace licenses needed?
Author rassnik
#1 | Posted: 8 Oct 2018 13:14
what if I buy a singel LigtSpace Cal license and run that one on a Notebook to do the following.
Calibrating monitors that are capable of loading 3D LUTs (e.g: EIZO's) should be fine with that single license, right?
But what would be the proper approach to to calibrate a bunch of other monitors (artists usually have one Eizo one sort of DELL monitors here). Would it still be possible to run that fromthat Notebook? Do I need additional licenses then?
Thanks in advance,
Tobias
#2 | Posted: 8 Oct 2018 13:30
One license on a laptop/notebook is all you need.
But, you will need ways to 'apply' any given calibration if using a LUT.
Author rassnik
#3 | Posted: 8 Oct 2018 18:16
Thank you for the response.
Is there a way to generate ICC profiles to load onto the graphics card (manually) or does it need to be applied via a LUT box?
regards,
tobias
#4 | Posted: 22 Jan 2019 16:07
Sorry - I missed this question.
Graphics card LUT (VCGT) are only 1D.
See the SpaceMan and SpaceMatch pages of the website for more info, and the new ICC Profiles page.
Author rassnik
#5 | Posted: 10 Feb 2019 01:06
Thank you for the answer - Even if its a little late
I was going through your enlightening reading recommendations. Very interesting stuff!
Need to check now if we can load 3D LUTs on all of our EIZOs.
Would it be ok to name the different models in here or should I research on my own?
Best,
Tobias
#6 | Posted: 10 Feb 2019 08:57
You'll find the answers for Eizo displays here:
https://www.lightillusion.com/eizo_manual.html
Author rassnik
#7 | Posted: 12 Feb 2019 17:24
Thanks Steve!
Will check which models we use and hopefully buy a license soon.
Best,
Tobi
