Hisense mini-LED correlation file for i1d3?
Author rdk914 Male
#1 | Posted: 13 Jan 2024 13:49
I am manually calibrating a Hisense U8H mini-LED ULED using a i1d3. When I use the White LED correlation file the OOTB grayscale is pretty close. When I use the TCL mini-LED correlation file the dEs are much higher and the green seems to be much lower at each level.
Is there a correlation file anywhere for the Hisense min-LED, or is the TCL file the correct one to use?
For now I am using Lightspace Connect as the TPG.
#2 | Posted: 13 Jan 2024 18:47
The correct Correlation File will depend on the screen used in the TV - but I doubt White-LED is correct.
Do Hisense define the screen used?
Author rdk914 Male
#3 | Posted: 13 Jan 2024 19:04
Hisense says it is a min-LED ULED quantum dot screen (I have the US 55" version). I don't see much more info than that. The AVS owner's thread for the TV indicates that it is a VA panel and also references BGR pixels - but I don't see that information on the Hisense spec sheet for the TV.
#4 | Posted: 13 Jan 2024 21:30
That info does suggest White-LED is not the correct option.
And it is best to use SPD2Matrix to verify any Corr. File before you use it.
Author rdk914 Male
#5 | Posted: 13 Jan 2024 22:15
Thanks for responding. I did a calibration with the White LED file and it actually looks pretty good to my eyes (my other TV is LUT-calibrated LG C9, so I'm used to an accurate picture), so that correction file is certainly not doing anything crazy. I will try with the TCL file and see whether it is noticeably different. I might post on AVS to see if anyone has a Hisense file they might be willing to share.
Online now: Guests - 12
