Help needed - Spectracal C6 with Lightspace dps
Author ablex
#1 | Posted: 16 Mar 2019 17:54
Hello everyone,
I Am getting into the world of calibration and made a sure mistake of getting a Spectracal C6 meter with hopes of using it with Lightspace dps or HFCR. After much reading and receiving the meter it turned out that i could only use it with calman software, with the meter bought solely for home use it is a bit expensive to buy the calman studio as home enthusiast has been discontinued.
I read from Ted's post on some forum that it is possible to use the spectracal c6 meter with Lightspace or HFCR and would like help in setting up the meter so that i can calibrate my TV. There was a mention of modified dlls but i have had no luck in find them.
All help will be deeply appreciated (Lightspace or HFCR use instructions and necessary files needed),
Regards,
Ablex.
#2 | Posted: 16 Mar 2019 18:41
Please see the information provide within the download email for the LightSpace software.
Basically, you need to contact Ted.
www.displaycalibrations.com
It is a shame you went for the C6.
It is just a very expensive i1D3.
No different at all...
Author ablex
#3 | Posted: 16 Mar 2019 19:00
Thank you steve, i have just sentTed an email and hoping to get some direction soon.
It was a very expensive mistake, took the leap to eary into calibration.
Able.
