HDCP Compliant IS Mini
Author sillysally
#1 | Posted: 6 May 2014 21:14
If you send a video signal from a Blu Ray player to a SDI converter box via HDMI cable to the SDI converter box and then out to a IS Mini 3D via HD SDI video cable .
Then run a HDMI cable to a display (VT60) from the IS Mini, would that work or would I just get a black picture on my display because of the Oppo being HDCP compliant.??
ss
#2 | Posted: 6 May 2014 21:29
Hello SS,
your idea will not work because Blu-Ray Movies have High-Definition Copy Protection (HDCP), so your whole equipment video signal chain must be HDCP compliant.
This will only working in case that you will author a personal blu-ray disk with content that you have not include HDCP protection, stuff recorded from personal camera maybe...etc..
I have created this spec. comparison table with the complete list of the 3D LUT Boxes / Video Processors that are currently available at pro industry/consumer market and can be used for Commercial Blu-Ray Movie Playback.
That comparison screens shows only the device features that are useful or can be used for HT use only.
#3 | Posted: 7 May 2014 08:18
That makes sense.
I use the combination SS suggests with my Laptop HDMI output, and all works fine.
HDMI from laptop > Blackmagic HDMI to SDI Mini Converter > Fujifilm IS-mini > Sony TV.
But I'm playing back footage from the laptop, using MP4/AVI clips, etc, not from any DVD/Blu-ray, so I guess HDCP is not an issue.
#4 | Posted: 7 May 2014 08:43
Hi Steve, sure there is no problem with media files, but with consumer blu-ray movies from stand-alone players HDMI to HD-SDI signal conversion idea can't work, because Blu-Ray Playback from Stand-Alone Player has Copy Protected HDMI Signal (HDCP).
If your notebook has Blu-Ray Drive and you can load a commercial movie, it will not output with you will have connected that HDMI->SDI converter.
For example:
BlackMagic Devices HDMI to SDI MiniConverter does not pass protected Signal... or
AJA HA5 HDMI To HD-SDI/SDI Video & Audio Converter will not pass HDMI video with HDCP copy protection too...
