HD2line Gamma 2.35
Author aterstudio Female
#1 | Posted: 23 Jan 2025 19:01
Hi is it possible to get the Target Gamma 2.35 instead of 2.4? HD2 line old series of monitors use 2.35 gamma instead of 2.4 regarding the earlier EBU specifications?
Regards,
Mirela Budimic
MIRELA Budimic
colorist/digital restoration artist
M.Arch
#2 | Posted: 23 Jan 2025 19:07
Yes, you can make any colour space you want, with any values for the target Red, Green, Blue, White and Gamma.
All is explain in the User Guides.
But using a gamma of 2.35 today is just wrong.
#3 | Posted: 23 Jan 2025 21:34
I completely agree. When calibrating older panels, the HD2line software typically uses a 2.35 gamma. To address this, I made a slight adjustment to 2.4 using Light Illusion, applying an additional LUT specifically for grading. Thank you Steve.
Mirela
MIRELA Budimic
M.Arch
 HD2line Gamma 2.35
Members - 1 [ Light Illusion ]
