FSi License for Multiple Monitors?
Author desmondqford
#1 | Posted: 20 Nov 2013 22:56
I'm about to purchase two FSI CM25 OLEDs.
Does this mean that I have to buy two of the special FSi/Lightspace Licenses?
#2 | Posted: 20 Nov 2013 23:21
Nope, just the one LightSpace FSL license needs for all your FSI displays.
Author desmondqford
#3 | Posted: 20 Nov 2013 23:40
Sweet!
Sorry for this last question, but I"m confused about the wording on the FSi website, which may just be semantics, so I just want to make sure...
If I understand correctly, this is a Full LightSpace CMS license, albeit only for use with FSi monitors? In other words, there are no limitations with the LS license for FSi, apart from the fact that it can only be used with FSi monitors.
Or is there a difference?
#4 | Posted: 21 Nov 2013 09:18
There are two Flanders specific versions of LightSpace.
LightSpace FSI, which is just about fully operational, except for Batch LUT Conversion, ASC CDL and ACES options, and only generates FSI LUTs.
LightSPace FSL (FS Light) is the same, but only works with the i1 Display Pro probe.
See: http://www.lightillusion.com/lightspace_options.html
All versions of LightSpace can be purchased directly from Light Illusion.
Members - 1 [ Archttila ]
