Found an optical match for Automatic Backlight Adjustment
Author Matthias Male
#1 | Posted: 3 Jan 2022 08:49
Hello folks,
as we all know, it is clearly recommended to avoid any automatic picture processing stuff, including automatic backlight. In the latest "Matrix Resurrection" movie, the opening sequence shows a blinking cursor, this clearly helps to identify, if any automatic backlight adaption is changing your video. Have a look at the attached video, 10 seconds, and you'll notice the lamp-on-off-effect on my 2020 Samsung The Frame.
Unfortunately, the original "The Matrix" (1999) has a very similar opening sequence, but I could not reproduce the same effect. At least not from the DVD release.
Matthias.
#2 | Posted: 3 Jan 2022 10:19
Seems, as the file was not attached in the original post.
#3 | Posted: 3 Jan 2022 10:22
Matthias
There are limits on file types/sizes, as the forum user info states.
To post a video, first upload to YouTube, and then use the YouTube button above the text area to link to it.
#4 | Posted: 3 Jan 2022 10:29
However - you can easily use the in-built test patterns within ColourSpace to test for such tests.
https://www.lightillusion.com/forums/display-calibration-8/fald-displays-724.html
Online now: Guests - 6
