Foot Lambert
Author Turnip Male
#1 | Posted: 25 Nov 2022 09:12
Hi! Is there an option in ColourSpace DPS to present the light measurement in Foot Lambert instead of Nits?
Regards,
Jan
#2 | Posted: 25 Nov 2022 09:48
Foot Lamberts have not been used for brightness measurements for any displays - monitors and projectors - for some time, and were removed from LightSpace/ColourSpace a long time ago.
Author Turnip Male
#3 | Posted: 28 Nov 2022 07:49
We are using Foot Lamberts every time for measurements in our visual systems, so I don't think it's obsolete everywhere.
Jan
#4 | Posted: 28 Nov 2022 08:23
We know of no display standard that still uses FtL?
What is your visual system, and why are you using FtL?
Author Turnip Male
#5 | Posted: 28 Nov 2022 08:38
In flight simulator visual systems every manufacturer always use FtL in the specifications. Guess it has historical reasons.
#6 | Posted: 28 Nov 2022 08:43
Do you have the specification standard documents?
All such setups we have ever seen used nits.
Author Turnip Male
#7 | Posted: 28 Nov 2022 09:00
Here are some information: https://www.easa.europa.eu/en/downloads/46529/en
I see that they specify both cd/m and FtL, for brightness, but I think it's more common to use only FtL, at least what I have seen.
Jan
#8 | Posted: 28 Nov 2022 09:11
Thanks for the link.
Based on reading that, I would use nits (Cd/m), as FtL is in brackets as a secondary measurement option.
 Foot Lambert
