FinalCalibration always showing a slight shift to yellow from the required Green point measurement.
Author harvey
#1 | Posted: 16 May 2016 18:17
This is first time i've used this software. So quite likely I have missed something obvious.
Calibrating a Colour Edge CG243W
Aiming for a Rec709 profile.
Probe is a Hubble.
Tried both DVI ports Target not quite %100. i.e. Coming up as 99%
Any ideas to make lime green to green.
#2 | Posted: 16 May 2016 18:19
Hi Harvey - we'll need to see the source profile, and the LUT you generated from it.
Please e-mail to me so I can have a look.
Author harvey
#3 | Posted: 16 May 2016 18:49
Hi Steve
Sent you an email with the tif and bsc. Hope that helps.
Harvey
#4 | Posted: 16 May 2016 18:57
Response sent
