Failed to Find an EIZO monitor
Author Jeff D Male
#1 | Posted: 6 May 2026 16:41
Hi There,
I'm running ColourSpace using VM ware on my macbook. I have attached my EIZO CG319X to the computer. The VM recognizes that my EIZO is connected. When I try to connect in the Hardware and Probe options I get the error "Failed to find an EIZO monitor."
Have had no issues using this set up with my i1D3.
Thank you for your help!
Jeffrey Di Lullo
#2 | Posted: 6 May 2026 16:46
I suspect that is an issue between the VM and the Mac OS.
Likely USB forwarding, or similar.
The i1D3 is a HID device, so will likely be treated differently.
All I can definitely say is it is not a ColourSpace issue.
Author Jeff D Male
#3 | Posted: 6 May 2026 16:54
Jeff D
After a third reboot and changing USB ports, ColourSpace now sees my monitor.
