Error with Lumagen Radiance Pro
Author ShadeRF
#1 | Posted: 22 Mar 2019 21:24
I'm getting the following error trying to connect to my Lumagen Radiance Pro: Alive check failed for Radiance on COM3. No response received ZQS00. I'm using the usb cable that came with it to connect and have been connecting to it fine with a different calibration software. Any suggestions for resolving this?
#2 | Posted: 22 Mar 2019 21:37
Could be a Lumagen old firmware issue?
Or baud rate?
Not really sure without more info on your setup.
But do check: https://www.lightillusion.com/lumagen_manual.html
Author ShadeRF
#3 | Posted: 22 Mar 2019 21:48
That was the guide I was following. I have the very latest firmware installed. Here's a screenshot of the port settings from device manager. https://www.dropbox.com/s/xm5853wxe83rygd/portcom3.jpg?dl=0
#4 | Posted: 22 Mar 2019 21:52
Have you tried a factory reset?
Note: If there are issues communicating with the Lumagen perform a Factory Reset, as it is likely the box has been set to an non-standard configuration, such as Termination sequence character, or Echo response.
Author ShadeRF
#5 | Posted: 23 Mar 2019 17:13
That worked. Thank you
#6 | Posted: 23 Mar 2019 17:13
Great!
