Eizo and ColourSpace
Author egosfera
#1 | Posted: 1 May 2020 14:41
Is ColourSpace LTE enough to calibrate Eizo 3D-LUT displays?
I know that Eizo displays with 3D-LUT have their own internal patch generator so no need for an external one.
But ColourSpace LTE does not provide patch generator integration.
I'm a bit confused if LTE is enough or CAL should be used.
#2 | Posted: 1 May 2020 15:02
If you look at the 'Features Matrix' on the https://www.lightillusion.com/colourspace.html page, you can see what displays work with what license levels.
Look at the 'Hardware' options.
LTE has 'Eizo' listed, so yes, it will work with Eizo displays with 3D LUT capability.
Author egosfera
#3 | Posted: 1 May 2020 15:06
Thanks for the tip. The feature matrix is quite informative.
