Eizo ColorEdge CS2400S - measurement / Correlation Files question
Author rzbrzezny Male
#1 | Posted: 7 Nov 2024 09:47
Hello!
I have Eizo ColorEdge CS2400S monitors and Calibrite Display Pro colorimeter. I would like to take measurements using Colourspace ZRO. After selecting the probe type (ColorChecker/Display/i1D3) I do not know what type of matrix to choose in 'Correlation Files for Calibrite/Xrite Colorimeters'. This is IPS Wide gamut Led (and having the Spyder X2 elite colorimeter I had this type of matrix to choose from) but here I do not know. In the 'Correlation Files' file there is no exact monitor model. Obviously, incorrect selection = incorrect results.
Can you suggest what to do in this situation?
Thank you!
Rafal
#2 | Posted: 7 Nov 2024 12:17
You would need to know the backlight that monitor uses.
But likely PFS Phosphor would be the best choice.
But, Corr. Files really are not accurate - check the posts on using SDP2Matrix to verify.
#3 | Posted: 7 Nov 2024 16:21
Thanks Steve,
the closest one seems to be the file "EIZO ColorEdge CS2731 (W-LED PFS) - Colorimetry Research CR-300 2nm". But I'll check the parameter you're talking about.
P.S. The program for measurement is fantastic!
Online now: Guests - 9
