Eizo CG2420 calibration
Author POD
#1 | Posted: 18 Apr 2020 14:45
I've purchased a 3 day rental of ColourSpace LTE and time is ticking. I have managed to run a monitor profile but can't figure create or apply a correction lut to the EIZO CG2420. Also the EIZO CG242 specs say it uses W-LED but I noticed on some posts here PFS Phosphor is mentioned for some EIZO models. Does anyone know which I should be using?
And a question for Steve. I have Calman's Virtual Forge pattern generator, will this work with ColourSpace?
Cheers
Phil
Philip O'Dea
#2 | Posted: 26 Apr 2020 10:35
Sorry - for the delayed response.
Hopefully you sorted the Eizo calibration?
And no, Virtual Forge will not be supported.
There are far better, and a lot cheaper, options for TPGs.
(But, the issue with integration has nothing to do with us... we are happy to integrate with any hardware, from any manufacturer.)
