EIZO 319x LUT position YUV
Author christianschwarz1
#1 | Posted: 3 May 2024 08:36
I am a little confused about that, can the 319x be used in YUV with a 3dLUT? So is the LUT after the YUV to RGB conversion?
#2 | Posted: 3 May 2024 09:04
That depends on the LUT location.
From the User Guide:
"...some EIZO monitors have two 3D LUT locations - Standard and Extended - with Extended being before the YUV to RGB conversion, and so will not work with YUV inputs. Standard is after the YUV to RGB conversion, and will therefore work with YUV or RGB inputs."
#3 | Posted: 3 May 2024 09:55
Hi Steve, yes I know that, but how can I verify if the 319x has Standard and or Extended?
#4 | Posted: 3 May 2024 10:32
Connect to the monitor, and check the options via ColourSpace.
https://www.lightillusion.com/eizo_manual.html
Author nhatdo Male
#5 | Posted: 3 May 2024 13:17
I owned Eizo CG319x and it have 2 slots LUT, Standard and Extended.
#6 | Posted: 3 May 2024 13:28
@nhatdo really? If I connect to the EIZO with colourspace LTE I can only choose Extended!!
Author nhatdo Male
#7 | Posted: 3 May 2024 15:47
Sorry my mistake, i mean TPG. Choose the extended on Lut process and run the calibration, i did many times and never have any issue. In TPG i choose Standard slot and get result around dE Avg 0.18
