EFI ES-3000 vs. i1Pro 3
Author jvisuals Male
#1 | Posted: 12 Aug 2025 20:20
I'm considering a few used EFI ES-3000 spectros on the market.
From my limited research, it seems that the EFI line is a basically an i1Pro 3, just with different branding. I see that Ted confirmed this back in 2023.
https://www.avsforum.com/threads/efi-es-3000-vs-i1-pro-3.3289757/
Can anyone confirm whether an EFI spectro will connect seamlessly with ColourSpace's i1Pro 3 probe selection? I'm curious if there is any internal software that would block this communication with Light Illusion.
#2 | Posted: 12 Aug 2025 21:16
Yes, works exactly the same as the xrite branded version.
It has no 'lock keys', as with i1D3 probes.
#3 | Posted: 23 Aug 2025 14:25
Excellent, thanks Steve! That model just arrived in the mail today and I can confirm that it works. Thanks so much.
Online now: Guests - 14
