EEcolor goes black with "unity - pattern"
Author Jan Klonowski
#1 | Posted: 13 Jan 2013 13:26
hi folks,
i using a brand new eecolor - thnx steve - unfortunatly im not able to calibrate it until now...
here my set up
aja kona lhi sdi -> sdi hdmi converter -> eecolor -> monitor
when im loading the unity table my screen goes mad.... no contrast may be monchrome or goes totaly black
any ideas for me
regards jan
Author buzzard767
#2 | Posted: 14 Jan 2013 13:13
What screen? Computer? Are you linked to the eeBox via USB cable?
Buzz
Author waltervolpatto
#3 | Posted: 14 Jan 2013 14:50
HI there.
What the purposes of eeColor, what you are trying to achieve?
Is the link between the SDI HDMI converter and the TV working ok? (Without the eeColor...)
Does the eeColor have a Bypass? can you test it?
Is there a "default" setting in the eeColor that you can test it?
Walter
