EDLs for Display Independent Profiling mode (DIP mode)
#1 | Posted: 13 Feb 2012 14:14
We've generated a selection of edls to automatically build the correct duration timelines on DI systems for DIP profiling using the exported patches from LightSpace CMS.
The EDLs use M2 commands, and have been tested on Mistika, Resolve, and Nucoda.
If anyone want to give them a test drop me a line.
#2 | Posted: 16 Feb 2012 19:25
The available edls can now be downloaded here: http://www.lightillusion.com/downloadcalibrationedls.htm
Cheers, Steve
Author Jean COUDSI
#3 | Posted: 23 Mar 2012 11:29
Work fine !
Excellent use with DaVinci RESOLVE on mac pro !
Author srinivas
#4 | Posted: 24 Mar 2012 10:26
I can't connect my patches to the edl in resolve. Can anybody tell me the settings or procedure?
Srini.
#5 | Posted: 24 Mar 2012 18:28
Hi Srini, you should just need to make sure the folder the dpx frames are in is the named the same as that used within the EDL (reel name), and then just link to that folder.
All should then just work.
Author Jean COUDSI
#6 | Posted: 30 Mar 2012 07:59
And in CONFIG -> TIMELINE CONFORM OPTION : don't forget to select From the source clip frame count
