Edge Color Test (255 patches) Measurement Run for ColourSpace ZRO
#1 | Posted: 26 May 2021 19:03
It's available for download the Edge Color Test sequence for ColourSpace ZRO users. Download Link
Edge Color Test will measure the border of the gamut (255 color patches) with about 20-Points that connect each primary/secondary color.
Additionally, it will measure 21-Point Grayscale, ~20-Point of Saturation of Secondary colors (CMY), and ~20-Point of Luminance of Primary Colors (RGB).
Edge Color Test Visualization:
2D CIE Chart of ColourSpace ZRO:
3D xyY Chart of ColourSpace HTL:
Normalized RGB Cube of REC.709 of ColourSpace HTL:
That measurement run can reveal issues to the edge of the gamut since some color engines tend to expand saturation to these levels, like a 'Shark Fin' effect:
Some other displays/projectors expand or compress the edge colors; you can also see if some enabled processing introduces any issues.
The Edge Color Test (26 May 2021) ZIP will contain three patchlist with different patchscale settings:
FULL (0-255)...PC users / DaVinci Resolve
LEGAL (16-235)... Consumer TV/projector evaluation
EXTENDED (16-255)... LG OLED 3D LUT evaluation of Calman's Autocal (Shark Fins detection) or Yellow de-saturation filtering of the new engine.
