Easy Excel Patch Scale Conversion Tool
#1 | Posted: 13 Feb 2021 14:26
See here an easy patch scale conversion tool, I have generated as an outcome of this thread.
Here the related instructions:
I will be happy to improve it based on your comments and suggestions.
EDIT/ADDITION: Working with patches, I have found it useful to have source patches directly in % value. For this reason, I have created a second version using that kind of input.
I have cross-checked it against the outcome of the 16-235 greyscale generated by CS, and the generated values match each other.
Patch Scale Conversion Tool .zip Attached file:
0-255 Excel conversion Tool
% Excel Conversion tool
#2 | Posted: 7 Mar 2021 22:58
Following CS extension to Resolution (10, 12, 14, and 16 bits) I have updated the excel tool to include also that parameter
See here the sheet allowing parameters settings.
The excel tool is also attached in a version generating automatically up to 256 patches. This can be easily extended.
There is also a "full" version doing the same, but up to 16000 values
Excel conversion Tool - Converted patch up to 256
Excel conversion Tool - Converted patch up to 16000
#3 | Posted: 18 Jul 2023 10:15
Here a new version allowing also conversion of decimal patches (0-100) as input.
Convert up to 1600 patches including 0-100 values
#4 | Posted: 4 Mar 2024 12:36
See here a version 2.
I have added:
1. Input forms to makes conversion setting more friendly and Patch scaling (see them in the Input Forms picture)
2. A way to outline duplicated patches, so to allow to remove them from the converted patch-set.
Patch Scale Conversion Tool (ebr9999) full size-V2
Input Forms
Input Forms
Members - 1 [ paulinventome ]
