Dolby PRM monitor integration
Author Vassily Male
#1 | Posted: 29 Sep 2021 13:40
Hi Everyone,
Did anybody succeed to connect the Dolby PRM display with ColourSpace? I do can ping the monitor but ColourSpace trying to connect with error. I disabled windows firewall and antivirus, does not help. Dolby support advises to set ip address to something higher than 192.168.1.20 and nothing else, they say if I can ping the monitor it should work.
#2 | Posted: 29 Sep 2021 13:46
Dolby displays are notoriously finiky...
All I can say is check, and the triple check, the provided instructions
https://www.lightillusion.com/dolby_manual.html
Author Vassily Male
#3 | Posted: 29 Sep 2021 13:54
I have quadrupel checked already but did not help
Ok, not a problem, internal dolby calibration lut looks good, but I wanted to chek if it can be better.
Best regards,
Vassily
