Display Calibration Tools - Lightspace Enhancement
Author mike_n
#16 | Posted: 9 Apr 2014 22:51
Bob,
thanks for the feedback !
- Mike
Author mike_n
#17 | Posted: 6 May 2014 11:04
Hi guys,
we've added a new free tool:
The i1 Display Pro Integration Time Calculator allows you to calculate the integration time of the i1 Display Pro (i1D3) colorimeter which can then be specified in Lightspace.
- M
Author mike_n
#18 | Posted: 22 Jul 2014 11:36
Hi guys,
new updates have been posted to DisplayCalibrationTools.com:
(1) Color Patch Sequence Editor Released
The Color Patch Sequence Editor tool allows you to load, edit, modify and convert any existing color patch sequences from Lightspace, Calman or Argyll.
(2) Updates To Existing Tools
The Custom Color Patch Sequence Generator has received the following updates:
> added 3D RGB color cube with zoom/rotate/filter functionality to patch set statistics
> added Hue image to Custom Patch Set section for easier hue selection
The Color Patch Sequence Viewer has received the following updates:
The Meter Distance & Pattern Size Calculator has received the following updates:
> updated instructions
Lightspace Profile Reporter: no changes
eeColor 3D LUT Analyzer: no changes
Lightspace Custom Color Space Creator: no changes
Lightspace Custom Meter Profile Creator: no changes
Meter Profile Comparison: no changes
i1D3 Integration Time calculator: no changes
(3) New Calibration Guide
A new cal guide has been added to the Display Calibration Guides & Workflows:
Advantage Of Custom Color Patch Sets In Display Calibration
- Mike
Author alex_t
#19 | Posted: 22 Jul 2014 19:57
Very good, thanks
Author mike_n
#20 | Posted: 23 Jul 2014 10:22
here are some images of the 3D RGB color cube and how it helps to analyze and visualize patch sets - examples of 2 validation patch sets:
LS 141 pt QP:
LS 141 pt QP
96pt Color Checker SG:
96 pt Color Checker SG
as you can see these 2 patch sets above are not great choices for calibration validation... huge holes in the cube (Color Checker SG) or no points between the center and the edges of the cube (LS QP)...
here's a 1,000 pt custom patch set used for validation:
custom 1,000 pt patch set
#21 | Posted: 23 Jul 2014 10:29
Mike, looks great!
Author mike_n
#22 | Posted: 13 Dec 2014 10:24
Hi guys,
new updates posted to DCT:
The Screen Uniformity Evaluator (SUE) tool has been released and a screen uniformity test comparison of the FSI CM250 (OLED), FSI CM171 (LCD) and the Qnix QX2710 has been posted.
Let me know if you have any questions.
- M
Members - 1 (hidden: 1)
