Delay before start of characterization
Author jonzener
#1 | Posted: 9 Feb 2025 02:45
Hi Nathan,
You can run a preroll of patches before the main calibration. The user guide explains how to export a patch set as a .csv file. You can then use this for the preroll patches. And you can set the display time per patch for any arbitrary amount, so you can both warm up the projector and time your exit accordingly.
Take care,
Jonathon
Author nathan
#2 | Posted: 9 Feb 2025 02:59
jonzener
Thanks! I tried running a pre-roll without a CSV file thinking that would be sufficient but of course that didn't work. I presume that since the CSV of patches running as a pre-roll are not being measured/recorded so it sort of doesn't matter what I run.
