Davinci generator - check LUT
Author rbhun
#1 | Posted: 17 Sep 2020 13:22
Hi
So I have created a calibration LUT with the Davinci patch generator - seemed the safest as this is the main use. I have loaded the LUT into LightSpace and checked the LUT back, getting good results. But how can I check the LUT in Davinci? According to Steve's guide the final check would be to load the LUT in its final place, and do a calibration run. How wet, it seems that the loaded LUT does not affect the patch generator Coming from Davinci (which I suppose is a good thing, unless when that's what you need...)
How can I do that? Or I should create a timeline with patches and manually start it?
#2 | Posted: 17 Sep 2020 14:27
Unfortunately that is one of the issues with the location of the TPG within Resolve - it cannot be used to verify a LUT held within the system.
So yes, your only option is to use the timeline, and run the patches in DIP mode
