CVS Files
Author sillysally
#1 | Posted: 1 Feb 2016 19:29
Steve, when using a CVS file there is no box to tick for Anisonetric.
Can you add this feature to use with a CVS file to prevent ASBL.?
ss
#2 | Posted: 1 Feb 2016 19:38
It's impossible for Ansimetric to be used with CSV patch sequences.
The Anisometric process has to calculate the actual patch values on the fly, based on the value of the previous patch - it cannot be used with sequences where patch values are predetermined.
You will need to 'order' the patches within the CSV file in the order you want them to be presented.
 CVS Files
