Cube Based Characterisation point spacing
Author argonaut
#1 | Posted: 28 Feb 2023 22:43
Looking at the percentage spacing of points used in Cube Based Characterisation, for Cube sizes 3 through 10, for Legal 10 bit (leaving out 0% and 100%):
3: 46.69%
4: 29.91%, 64.04%
5: 21.80%, 46.69%, 72.83%
6: 17.01%, 36.53%, 56.96%, 78.20%
7: 13.93%, 29.91%, 46.69%, 64.04%, 81.85%
8: 11.76%, 25.23%, 39.38%, 54.00%, 69.06%, 84.36%
9: 10.16%, 21.80%, 34.02%, 46.69%, 59.59%, 72.83%, 86.30%
10: 8.90%, 19.06%, 29.91%, 40.98%, 52.40%, 64.04%, 75.80%, 87.90%
It's clear the points could be more uniformly spaced, but aren't. What's the rationale for why they aren't?
Author Light Illusion Male
#2 | Posted: 1 Mar 2023 00:55
All I can say is the spacing is very deliberately not uniformly spaced.
But, as you can make any patch sets you want, you can use any spacing you want.
Author argonaut
#3 | Posted: 1 Mar 2023 01:10
Given that the spacing is the same, regardless of Gamut/EOTF, that seems like very little rationale.
#4 | Posted: 1 Mar 2023 01:25
Please feel free to use any spacing you want.
That is one of the beauties of ColourSpace - you are not restricted to any given patch set for profiling.
As with most of ColourSpace operation, there are no set restrictions.
