Create custom patch sequence / merge patch sequences
Author zmas Male
#1 | Posted: 2 Sep 2022 13:00
Is it possible to export some of the standard patch sequences like the Grayscale Large, Memory Colours and Gamut Sweep sequences and merge them into a single patch sequence?
#2 | Posted: 2 Sep 2022 13:08
Indeed - just use Manage in Characterisation to Export Sequence, which exports a .csv file of the selected patch sequence, and then use Excel to edit as you want/need.
Members - 1 [ Steve ]
