Create .edr profile for i1 Display Pro from i1 Pro3 offset Measurements
Author zmas Male
#1 | Posted: 2 Nov 2025 20:02
Does someone know how to create an .edr correction file for the i1 Display Pro?
I have measurements of the QD-OLED display I'm calibrating done both with the i1 Display Pro and the i1 Pro3 in Colourspace.
I'm playing around with the ASUS Calibration software, and it doesn't have an option to profile the colorimeter against the spectro.
#2 | Posted: 3 Nov 2025 09:57
ColourSpace doesn't use EDR files.
#3 | Posted: 3 Nov 2025 12:05
QD-OLED spectral correction files are available for import into your ColourSpace:
https://lightillusion.com/forums/msg.php?id=8827
Author zmas Male
#4 | Posted: 3 Nov 2025 12:35
I have no issues creating the probe correlation data in colourspace or importing one.
What I asked is as is someone has the know how on to convert that into a .edr file because that is what the Asus calibration software uses.
#5 | Posted: 3 Nov 2025 13:59
Ah - we obviously do not use any manufacturer calibration software, so have no idea what they use.
But no Corr./EDR file is guaranteed to be accurate.
Author zmas Male
#6 | Posted: 3 Nov 2025 14:18
Ok. Thank you Steve.
If anyone not necessarily from Lightillusion else happens to know how to do this I'd appreciate the help.
#7 | Posted: 3 Nov 2025 18:41
Have you Googled "CCSS2EDR"? You might find some good info.
Author Omardris
#8 | Posted: 6 Nov 2025 09:23
zmas:
Interesting. I had thought that there were hardly any applications left that used the EDR file format.
That's why I shelved a project for a tool that performs the relevant measurements and creates CCSS, correlation, and EDR files. This should also include the necessary interpolation to 1 nm resolution.
Maybe I'll revive this idea during the dark autumn days.
Members - 1 [ HeBer_nl ]
