CR-100 - Possible Issue with CRIapp
#1 | Posted: 27 May 2016 10:01
There seems to be a potential issue with the CRIapp leaving the CR-100 in a state that stops LightSpace from correctly setting the probe configurations – specifically Sync frequency, and possibly Exposure Time?
What we have found is that if using the CRIapp software to make changes to the probe you must take a measurement after making any changes, and then disconnect the probe from within the software and then also disconnect from the PC (so powering down the probe), before re-connecting to the PC, and then starting LightSpace.
If you do not do this, occasionally the CR-100 can be left in an incorrect configuration, and will not accept LightSpace commands.
Colorimetry Research are working on this issue.
Author alex_t
#2 | Posted: 27 May 2016 12:14
Hello Steve,
Thank you for the information, do you know if it concerns only the last CRIapp version or all CRIapp version ?
Alexandre
#3 | Posted: 27 May 2016 12:31
I have found this with all CRIapp versions I have tested...
But as I say, the above workaround works, and CRI are looking into the issue.
Author alex_t
#4 | Posted: 28 May 2016 07:32
Hello Steve and thank you.
Alexandre
