Compensating for a colour shift caused by a front projection screen.
Author AnthonyHoward
#1 | Posted: 20 Jul 2017 20:00
I am fairly new to all this but managing to get some reasonable results so far. However I am getting some pretty poor low light level results and would like to measure from the lens as opposed to from the screen to see if this can be helped. I am aware that the coatings on some screens can affect the colour performance and I would like to correct for this in my measurements as best I can.
Is it as simple as measuring from the screen and then using this result as a reference probe when measuring from the lens or is it more complicated than this?
I am using a retail Xrite i1 Display Pro.
Many thanks,
Anthony.
#2 | Posted: 29 Jul 2017 14:58
Yes, using the 'screen' reading via probe matching, and direct from the lens should indeed work.
Worth testing at any rate!
#3 | Posted: 1 Aug 2017 02:21
Thanks for the response Steve. I shall give it a try!
