ColourSpace, Resolve, and i1 Display Pro Not Reading Patches - And Bad Calibration Results
Page  Page 3 of 4 :  « Previous  1  2  3  4  Next »
Author J_Coy
#31 | Posted: 2 Sep 2022 13:00
I was using a 2k scope timeline but then switched fo a 1920x1080 one and bypassed all grades. I'll do as you suggest and report back.
Author J_Coy
#32 | Posted: 2 Sep 2022 13:05
I also don't understand how the black level says .28 nits, as when I test black level with the i1 D Pro, I usually land around .09 nits in Uniformity mode, and around .078 in Brightness mode (Eizo CG279x).
#33 | Posted: 2 Sep 2022 13:15
Until you fix the TPG issues, anything else is really irrelevant...
It may be the same issue - but you will not know until that is fixed.
Author J_Coy
#34 | Posted: 2 Sep 2022 13:18
Right, that does seem to be the root of all of this.
Author J_Coy
#35 | Posted: 2 Sep 2022 13:25
This might be a dumb question, but this point has always confused me--If I am sending Video levels out of Resolve (Video vs Data tab under Video Monitoring in Master Settings), should my Patch Scale be set to Full or Legal if using Resolve as the TPG over Network? I've always left the Patch Scale at Full.
#36 | Posted: 2 Sep 2022 13:28
That also depends on if your timeline is set for rescaling, or not.
There are multiple locations where rescaling can occur within Resolve...
You have to have the entire signal path set correctly.
Author J_Coy
#37 | Posted: 2 Sep 2022 13:34
The timeline in use also has Data Levels set to Video, just like the Master Settings. Video Bit Depth in Resolve (both Master Settings and Timeline) is set to 10 bit, ColourSpace's Resolution set to 8 bit.
#38 | Posted: 2 Sep 2022 13:50
You would really need to discuss that with a Resolve specialist.
We do not use Resolve ourselves.
Author J_Coy
#39 | Posted: 2 Sep 2022 13:52
Jeez, this is so confusing. Ive attached two images--one is from a manual measure of the monitor's black point, which reads around .09 nits. The other is from the LUT Generation window, in which my Min luminance reads at a whopping .5886.
Author J_Coy
#40 | Posted: 2 Sep 2022 13:53
Understood, Steve. I will just use a different TPG in ColourSpace, see if my results are more what I would expect to see.
#41 | Posted: 2 Sep 2022 13:53
That will be all part of the 'Sync' issue, as has been mentioned before.
#42 | Posted: 2 Sep 2022 13:56
J_Coy:
I have no idea what you mean there - there is no 'other' TPG in ColourSpace.
You are using Resolve as the TPG...
Author J_Coy
#43 | Posted: 2 Sep 2022 14:01
Ah, misspoke. So in my scenario, my options for the TPG are Resolve or the Eizo monitor itself?
#44 | Posted: 2 Sep 2022 14:03
Or direct HDMI from the ColourSpace PC...
https://www.lightillusion.com/direct_profiling.html
All options will help you isolate where the issue is when using Resolve as the TPG.
Author J_Coy
#45 | Posted: 2 Sep 2022 14:06
Great, I'll read through the Direct Profiling link you sent and give that a shot.
