ColourSpace MadVR TPG
Author vonswiss
#1 | Posted: 13 Jun 2020 13:48
Good Day
Unfortunately I can't connect an external MadVR TPG via network.
LAN connection in MadVR is enabled. IP ping is possible.
But in ColourSpace there is always an error message .
Failled to Conection to 192.168.1.118.
Does anyone have any idea what it might be?
#2 | Posted: 13 Jun 2020 16:14
Please check the User Guide:
https://www.lightillusion.com/madvr_manual.html
(If using madTPG over a network check the Windows mad tray icon settings via a right click, and make sure LAN Access is Enabled)
And also check your firewall settings.
Author vonswiss
#3 | Posted: 13 Jun 2020 16:31
Hi Steve.
MsdVR Lan ist enable.
What Kind of Windows Firewalls?
#4 | Posted: 13 Jun 2020 16:35
vonswiss:
I have no idea - what are you using?
Author vonswiss
#5 | Posted: 13 Jun 2020 16:51
Hello Steve
Sorry, Windows 10 Pro.
And my english is not so good.
On my HTPC with Lightspace, I can use my other laptop with MadVR.
On the laptop with ColourSpace, Windows 10 is also installed.
Ping I could the IP.
But with computer name or IP a connection could be established
#6 | Posted: 13 Jun 2020 16:53
Please check the firewall settings.
https://www.online-tech-tips.com/windows-10/adjust-windows-10-firewall-settings/
Author vonswiss
#7 | Posted: 14 Jun 2020 12:45
Hello, Steve.
You were right.
Had to disable the firewall.
Now is working.
Thanks for your help.
Author who Male
#8 | Posted: 8 Dec 2020 06:52
vonswiss,
It's not a good practice to leave the firewall disabled.
Please re-enable it when you're done connecting to MadVR.
Else create a firewall rule to allow access.
