ColourSpace - LightSpace Connect - connection issues
Author zmas Male
#1 | Posted: 21 Aug 2022 10:16
I'm running ColourSpace on a m1 MacBook Pro via Parallels.
I want to profile my 12'9 iPad Pro using the LightSpace Connect App; however, I can't get the app to connect to the iPad.
I downloaded the Mac Version of the app and that connects with no issues. Both devices are running on the same network.
Parallel creates its own subnetwork for the Windows VM, which is probably why the iPad can't connect. Anyone has experience trying to connect LightSpace Connect when Colourspace is running on a VM?
Author vlut Male
#2 | Posted: 21 Aug 2022 11:37
Try setting the Windows VM to 'Bridged Network (Default Adaptor)' you should then be in the same network as your iPad. I have it working with Win 11 with the Apple Arm M1 chip.
Victor Aberdeen - aulwa
Media Engineers
Author LasVegas
#3 | Posted: 21 Aug 2022 11:43
zmas
I have no experience with LightSpace Connect, only running Windows on M1 with Pararellels.
There are some scenarios where Bridged Network has worked better for me, instead of the default/recommended Shared Network option.
If you tried that already, I have no more ideas...
Author zmas Male
#4 | Posted: 21 Aug 2022 19:13
thanks for the reply, I haven't tried that yet. I will give it a go
Author zmas Male
#5 | Posted: 22 Aug 2022 08:46
Changing the network settings to bridged mode did not help. For a curious reason, the VMs IP address was still in a different range than my network, but I assigned it free IP withing my network range, and it worked. Only downside is that it lost internet connectivity in the process.
