ColourSpace and Calman
Author jednc1 Male
#1 | Posted: 23 Jan 2023 18:17
Can ColorSpace and Calman exist on the same computer without issues? This question would include DeviceControl as well.
#2 | Posted: 24 Jan 2023 09:21
As we never use Calman, so have no idea...
But we think Calman may use some non-standard probe drivers, so that may be an issue?
DeviceControl is usually installed with ColourSpace, so no issue there.
#3 | Posted: 24 Jan 2023 13:11
Yes, they can. Calman keeps its drivers in a different location from ColourSpace, so no issue there.
#4 | Posted: 24 Jan 2023 13:12
RollsRoyce:
Yes, you can. Calman keeps its drivers in a different location from ColourSpace, so no issue there.
Good to Know!
Author jednc1 Male
#5 | Posted: 24 Jan 2023 13:58
Thanks, I was mostly concerned that DeviceControl would screw with the drivers.
#6 | Posted: 24 Jan 2023 17:03
jednc1:
Nope. That's separate and nothing to do with the drivers.
#7 | Posted: 25 Jan 2023 10:44
jednc1
The installations of Calman/ColourSpace or DeviceControl are not using any common file.
CalMAN users of PGenerator always use DeviceControl to configure the TPG or inject patterns using Ted's Template.
You will not have any issues.
Online now: Guests - 7
