Colorimeter calibration
Author Headlong Male
#1 | Posted: 22 Jan 2026 16:47
Hello,
How often should a colorimeter be calibrated or is it necessary if you have a spectrophotometer? I've read some varying opinions on this so I thought I'd ask here.
#2 | Posted: 22 Jan 2026 18:01
https://lightillusion.com/probe_matching.html
A spectro is really needed.
Without a Spectro a Colourimeter cannot be 'calibrated'.
And if you use an i1D3 the Correlation Files are really not that accurate, as shown on the i1D3 page, and discussed in the SPD2Matrix posts.
https://lightillusion.com/i1d3_manual.html
#3 | Posted: 22 Jan 2026 18:09
Thanks Steve. What I'm referring to, is the recertification/"calibration" some manufacturers offer for their colorimeters, Colorimetry Research for an example. I guess this is then not quite the same as what's done to spectros when they are recertified?
#4 | Posted: 22 Jan 2026 18:11
No - not the same.
That just certifies the the Colourimeter is operating within defined parameters.
It does not make it 'accurate' to any given display technology.
#5 | Posted: 22 Jan 2026 18:16
Oh got it. Do you have any idea how often calibrators recertify their colorimeters or how often it should be done?
#6 | Posted: 22 Jan 2026 18:22
If you are using a Spectro it's not really relevant.
But all this is only valid with high-end probes.
No low-end probes can be manufacturer corrected - just checked they are still within tolerance.
#7 | Posted: 22 Jan 2026 18:23
Alright, thanks!
#8 | Posted: 22 Jan 2026 21:25
Headlong
Hi-end colorimeters have the capability for recalibration (Klein/Colorimetry Research/Minolta, etc.), not the X-Rite/Calibrate or the branded OEM from CalMAN (C6HDR2000/C6HDR500, etc.).
https://lightillusion.com/forums/msg.php?id=4963
#9 | Posted: 23 Jan 2026 07:03
ConnecTED
Hi TED and thanks. I have a CR-100 and was wondering if I should recalibrate/recertify it at some point. Judging from what Steve said, there's no need if I have a spectro.
#10 | Posted: 23 Jan 2026 08:04
You would want to have the Spectro recalibrated though.
#11 | Posted: 23 Jan 2026 08:10
Yeah for sure, about once a year right?
#12 | Posted: 23 Jan 2026 08:20
I'd say every 2ish years, depending on use and storage.
