Color Space Reports of Manual Calibration measure session: How to populate a Report Layout (preset or custom) with last measure session data?
Author AndreaL Male
#1 | Posted: 28 Aug 2024 15:06
Hi, I've tried to read some post here and some items on Interactive manual too, but I've not succeded to undestand how to populate a Report Layout with data coming from a measure session, (I'm particularly interested in Manual Calibration); Could you address me to any resource to find what I need? thanks a lot
Andrea
#2 | Posted: 28 Aug 2024 15:24
When taking manual measurements, each measurement builds into a profile.
You save the profile as normal, and then use that to load into a report.
Author AndreaL Male
#3 | Posted: 29 Aug 2024 10:09
Thanks Steve, after further few hours of struggle I've succeded in that, but thanks anyway!
My first difficulties were to understand in which tab and in which way I could save:
custom Workflow relative to my measures,
custom measure session profiles
And then, to understand how to choose a profile from those previously stored and associate it to selected report Layout
(I've found the relative selection combo box).
But Now I would have another question:
I've figured out on interactive manual that we can use a custom filter to show up various selections of data measure in the report;
So, at the while I'm going to go into further attempts to understand all advantages of that feature, I would ask you if it is possible to select other derivated form of delta-E that are not present in the relative selection combo box (I mean for example the Delta L*u*v* without considering Luminance error).
Thanks again a lot for your help
#4 | Posted: 29 Aug 2024 10:27
All options for Custom Filters are shown in the relevant User Guide.
Online now: Guests - 6
Members - 1 [ twitt88 ]
