Change for the points info list
Author vinturbo Male
#1 | Posted: 21 Aug 2024 11:17
Would it be possible to add a function on the POINTS LIST to reorder measurements based on measured luminance, or based on target luminance?
On some occasions it may be necessary to check low luminance readings to possibly re-read them with the probe (with different readout parameters). If I have for example a list of 4913 readings, it is very inconvenient to read them all to find that they need to be checked.
What do you think?
#2 | Posted: 21 Aug 2024 11:44
The Custom Filters option (in HTP/PRO and above) is really what you need.
You can filter any points using formula arguments.
#3 | Posted: 21 Aug 2024 11:50
Thank you Steve, i'll test
