CG279x - Can't upload LUT after characterization with ColourSpace
Author J_Coy
#1 | Posted: 21 Nov 2021 15:22
Just upgraded from LightSpace and having a number of issues--
1) My characterization (ex: "New_3") is not showing up in my Destination drop-down of the LUT Generation page/window/pop-up.
2) When I do manage to create a successful LUT, I don't have the option to upload it to my monitor within the Hardware Options menu back in the Profiling page/window/pop-up.
3) If I use the Eizo monitor instead of the network/Resolve connection, I cannot customize the size of the patches on the monitor (L10, 20, 30 etc).
Am I missing something here?
#2 | Posted: 21 Nov 2021 16:04
1) You need to 'Save' any profile after generation for it to appear in the library.
2) You need to be connected to the Eizo within the Profiling menu to have access to its options.
(You can have multiple Profiling windows to connect to different Hardware.)
3) Eizo displays do not have variable patch sizes - that is a limitation of the Eizo display's internal TPG- they are just Full Screen.
Author J_Coy
#3 | Posted: 21 Nov 2021 16:12
Understood. Everything seems to be working correctly now after a quick test. Thanks for getting back to me so quickly, Steve!
#4 | Posted: 21 Nov 2021 16:13
