Can i use BT1886 for bright room viewing?
Author Mikedagreat90
#1 | Posted: 23 Jan 2019 07:27
Hi everyone. As my title suggests, can i use bt1886 for bright room viewing if my measured bt gamma averages at 2.32?
Thank You
#2 | Posted: 23 Jan 2019 08:30
BT1886 is not designed fro any specific brightness of viewing environment.
It is based on the black level of the display.
We do not recommend it at all.
See: https://www.lightillusion.com/error.html#bt1886_gamma
#3 | Posted: 23 Jan 2019 09:16
Thank you Steve for your input
However lets forget bt for a monent. Lets take the fact of my average 2.3. Can i use 2.3 for bright room at 150 nits? Or is 2.3 as average recommended for darker room at night?
Thank You
#4 | Posted: 23 Jan 2019 10:43
The problem is a BT1886 gamma will have a much brighter gamma in the shadows, so will wash-out in a bright viewing environment.
You need the gamma to be brighter in the mids, which means a power law gamma - 2.2 usually.
#5 | Posted: 23 Jan 2019 16:17
The weirdest part after testing it out is that actually my shadows are not lifted but actually avtad bit darker than a flat 2.2. Thats why i wonder on my lcd how comes it doesnt lift shadows? And its evident that my average gamma is 2.32. No matter i will keep 2 seperate calibrations for day view one with bt and one 2.2 both at 150 nits and see which i will stick with hopefully
#6 | Posted: 23 Jan 2019 16:23
That all depends on the black level of the display.
Quoting an 'average' number for BT1886 really means nothing.
You should plot the display gamma vs. a power law 2.2/2.4 gamma, using a 'Differential Gamma' graph as per the above link.
Then you will see what is really happening.
