Calman C6 meter
Author Johnvnross
#1 | Posted: 10 Dec 2016 15:14
Hi folks - Does the Calman C6 meter work with Lightspace? Thx.
#2 | Posted: 11 Dec 2016 01:29
The C6 probe is just an X-Rite i1D3 (i1Display Pro) probe in drag, and far more expensive.
There is nothing special about the C6 probe, and even the supplied 'certification certificate' is inaccurate, as it is not NIST compliant.
The standard i1D3, or even the i1D3 Plus, as both are identical, and a LOT cheaper.
Additionally, LightSpace/ColourSpace has an EDR for WOLEDs that will work with any i1D3 probe, and is not restricted as with the C6 options.
Cheers,
Author yovmoor
#3 | Posted: 23 Dec 2016 20:40
Yes it's seem Calman add some profile inside the firmware.
Steve I want to take your CAL version of lightspace, does the C6 are supported on it? Thank you if you can help me.
#4 | Posted: 24 Dec 2016 01:09
No, there are no changes to the Firmware in the C6 vs. the i1D3 at all.
It is exactly the same as the i1D3.
 Calman C6 meter
