Calibration Client for Unreal Engine 5 or Disguise Designer
Author kameflex Male
#1 | Posted: 10 Jul 2024 08:09
Is there any way to have Disguise Designer or Unreal Engine output color patches remotely from LightIllusion ColourSpace?
We often take measurements in ColourSpace HTP on the LED Wall for a Virtual Production studio.
The Windows PC that outputs to the LED Wall is usually located in the server room.
Therefore, we install a JAVA App (Light Illustion Calibration Client included General downloads) on the PC in the server room,
We measure by remotely outputting color patches from the studio where the LED Wall is located.
When measuring Windows desktop, I can use the aforementioned method, but when using SDI output from Disguise Designer (outputting RenderStream from Unreal Engine), this method cannot be used.
#2 | Posted: 10 Jul 2024 09:47
That would require have Disguise and/or Epic Games provide us an API for integration.
Epic Games are a multiple ColourSpace license customer/user, so it's possible they have their own in-house capability...?
Also, the Home Cinema ColourSpace licenses lacks the Image Sequence Probe.
You really would find that of major benefit.
https://lightillusion.com/image_sequence_probe.html
#3 | Posted: 16 Aug 2024 07:57
Thanks for your quick replay and I am sorry about my late response. I will consider upgrading my HTP license to a Pro license.
