Budget display, internal LUT?
Author wiski15b
#1 | Posted: 2 Jun 2017 18:59
Is there a list of computer monitors with internal hardware LUT capabilities that lightspace can interface with?
I was looking to purchase one of these budget monitors that have internal LUT's, but not sure which, if any work directly with lightspace. I know I can use resolve output LUT or get a lut box, but would prefer one of these if I could. Thanks.
Dell PremierColor UP2516D 25"
BenQ SW2700PT 27"
HP dreamcolor (not sure if they have internal LUT's)
Maybe used NEC multi sync PA271w
Acer, viewsonic????
Ron
#2 | Posted: 2 Jun 2017 19:05
Please look at the Displays listed in the 'LightSpace Integration Guides': http://www.lightillusion.com/tech_info.html
But, few PC displays are suitable, other than Eizo, as they do not allow user calibration.
(Although NEC do have LUT capabilities, but lack the required sync frequencies...)
Author wiski15b
#3 | Posted: 2 Jun 2017 20:12
Sync frequencies?
Thanks again Steve,
Ron
#4 | Posted: 2 Jun 2017 20:14
Sorry - better to say frame rates...
Author wiski15b
#5 | Posted: 2 Jun 2017 21:08
24 fps should be 72 or 120hz? Sorry, I'll research a little more if necessary.
#6 | Posted: 3 Jun 2017 11:20
24 should be 24fps...
Author wiski15b
#7 | Posted: 3 Jun 2017 15:01
Ok to grade 4k on 1080 display? Probably set output to 1080 from resolve or just work in 2k timeline....
#8 | Posted: 3 Jun 2017 17:37
Colour has nothing to do with resolution, so no, there would be no issue with grading.
Author wiski15b
#9 | Posted: 3 Jun 2017 18:00
Thanks again Steve.
Author wiski15b
#10 | Posted: 5 Jun 2017 00:17
Anyone one here any experience with the Sony x800D? I've read some reviews that look promising. Gamut, black levels etc....
