BenQ PV270 connection issue in LightSpace LTE
Author J_Coy
#1 | Posted: 19 Mar 2019 11:49
Hi forum,
I've performed a full characterization of my BenQ PV270 and created a 3D LUT, which was then rechecked and verified. However, I'm running into an issue when I follow the guide for uploading the LUT to my PV270's hardware.
The Upload pop-up window allows me to select BenQ as "device type," but even though I can tick and un-tick NULL Cube, the "Monitor Name" selection is greyed out, and "Select Cal Set" is empty. If I just hit Upload without selecting a monitor, I get an error message about failing to initialize the BenQ monitor.
I am running Windows 10, and the monitor is connected to the LightSpace PC via USB that was supplied by BenQ. Does the monitor need a driver download or some kind of firmware update?
#2 | Posted: 19 Mar 2019 12:14
Have you checked the have the latest BenQ firmware in the display?
And the same with the driver.
Author J_Coy
#3 | Posted: 19 Mar 2019 12:16
Thank you for the response, Steve. I believe I have the driver installed (computer recognizes display as BenQ PV270 in Device Manager), but I'm not sure about BenQ firmware within the display. How do I check this?
#4 | Posted: 19 Mar 2019 12:23
You will have to talk toBenQ.
We do not have access to their firmware.
#5 | Posted: 19 Mar 2019 12:25
Oh - and make sure you have a direct video connection too, as the User Guides states.
Author J_Coy
#6 | Posted: 19 Mar 2019 12:29
I will contact them immediately, Steve. Thank you.
I do have a direct video connection as well as the USB connection. It's currently using DP, but I performed the characterization with TPG from Resolve, connected through HDMI via BMD's Mini Monitor 4K decklink card.
Author J_Coy
#7 | Posted: 19 Mar 2019 13:16
Huh...the correct monitor name (PV270) and Calibration Set options finally popped up on their own. Not exactly sure why, perhaps I just needed to wait a little longer? Anyway, I'm going to continue with the BenQ guide on Light Illusion and get this all finished up!
#8 | Posted: 19 Mar 2019 13:20
Weird - while the display is slow to communicate, it's not normally that slow...
Author J_Coy
#9 | Posted: 19 Mar 2019 13:22
That's what I figured. It definitely seemed like something wasn't being communicated between monitor and PC. Not exactly sure what changed. the LUT is 80% uploaded, I will report back on the progress and see if I can figure out what was going on with the connection.
Author J_Coy
#10 | Posted: 19 Mar 2019 13:33
LUT uploaded correctly to the PV270! Very strange behavior there for a while. I'm going to continue working in LightSpace and continue to refine the LUT, but it's good to know that the upload process works now. Thanks a bunch, Steve! Love this software so far.
Author J_Coy
#11 | Posted: 19 Mar 2019 17:09
Extra question: for profiling a PV270, I want to select RG Phosphor under Calibration Settings, correct? The panel is a GB-r LED.
#12 | Posted: 19 Mar 2019 17:12
Actually, you would need to check with BenQ.
I can't remember if it is a PSF Phosphor, or not.
Author J_Coy
#13 | Posted: 19 Mar 2019 17:13
Understood, thank you.
