ASUS PA27UCDMR Questions and observations
Author paulinventome Male
#1 | Posted: Today 08:28
I've been testing some OLED displays recently. Last one I did was the Tern 16" OLED which was pretty impressive (I think it's the same laptop panel that SmallHD and some others use)
But right now I have a PA27UCDMR which is the model below the SDI input one. It comes from factory calibrated <1 dE and has on board LUTs but it does not have a probe on board.
My first few attempts are profiling suggest that the 709 calibration is pretty far away from their spec. Which makes me think there's something up in my chain (I've done DeckLink/Direct and so on)
But I am a bit confused as to what Colourspace integration means for this model, I have been through the site and forum and googling and there are nods to a built in TPG in the monitor? Or that the monitor can be connected via USB for control from Colourspace - but is that just the model above with a probe? This model is listed as supported on the ASUS page on the website but not really how it is supported by Colourspace? I've also seen a form post about connecting a probe to it's USB for closed loop calibration but again I've not really seen this working yet (I'm running an older PC workstation so there could be USB-C issues here)
So before heading down this path can I ask what I should expect from Colourspace <> PA27UCDMR integration? And whether anyone else has used this, the smaller sibling to the 32.
Kindest
Paul
#2 | Posted: Today 08:44
All ASUS ColourSpace Integrated monitors are listed on the website: https://lightillusion.com/asus_manual.html
Along with instructions.
#3 | Posted: Today 12:08
I did read all of that. But I don't know how this relates to the PA27UCDMR which is listed on the page as supported.
I have it connected via USB, I can see it on USB Device Tree Viewer as PA27UCDMR and I can see a i1Display3 probe connected to the USB A on the monitor.
It is connected via HDMI to an internal GPU at the moment (I would normally connect via DeckLink but trying to keep thing simple)
I run Colourspace as Admin and then look at connecting to ASUS Internal but it says connecting for around 5 seconds and then Error. Can we tell what the error is?
I'm trying to understand what I should be able to see and do. I am on v1.0.1.2279 which was march 26 updated.
Kindest
Paul
#4 | Posted: Today 12:13
First, when using ColourSpace the probe must be connected to the ColourSpace PC.
And if you have connected to the correct USB socket on the ASUS it will just connect, unless you have one of the issues caused by third party programs, as explained in the User Guide, and has been discussed in there forums many times.
